Fuel hose
(In Topic #114905)
Fuel hose
Hi all,
I started my car for the first time in two years without a problem, the car was running sweet. Then i noticed a puddle of fuel on the floor. 8O
On closer inspection i found the leak (which is more of a squirt) on the upper hose that is connected to the fuel accumulator.
The lower hose looks in pretty bad condition as does the accumulator so i have decided to replace both hose's and the accumulator.
Anyway simple question is, what are the hose's called, and should i also be replacing the hose's after the two shorter ones. I do know that Crazyquiff and GSF sell the hose's but which ones do i need.
The fuel system is standard k-jet. 1.8 gti
Thanks.
Phil
Thanks.
Phil
its the top 2 pipes you need from the fuel pipe section on crazyquiffs site:
Fuel Hose 171201218C
Fuel Hose 171201220D
he does a kit wi both 'ASL + FPA FPKIT ?67.00'
Thats great cheers mate.
Been struggleing to get hold of him.
Phil
Phil
no problem, its worth checkign the main lines as well, chances are they wont be in the best condition either
I will have a good look at the main ones,
They didnt look to bad but i will only know when the others are off.
Cheers again
Phil
Cheers again
Phil
