fan belt rubbing when lights are on!!
(In Topic #131167)
this is a problem i've had for a while and has been in and the gerage for some time.
when i run the car during the day it runs great but when i put lights or radio on i hear a squeling noice from under the bonnet. i did bit of of research and found with the bonnet open and enginge running i turned lights on to see the fan belt move slightly which caused it to rub on cambelt cover. why would it do this.
Number on alternator is 026 903015 0r 0120489362 363 and k1 14v 23/55v its a 18gti cabrio here are some pics
any help advise would be great
Twitter Manager
chortle when you said garage put wrong one on do you fan belt or altanator. also why would fan belt move move?
The bottom crank pully looks brand new? Are all 3 pullys in line?
Also the early belts do stretch and slip a bit esp initially, later ones moved to the Ploy-Vee types. I'd try and tighten it up a bit more.
<a> <img></a>
