Erratic temp gauge
(In Topic #92619)
Erratic temp gauge
As soon as I start the engine from cold the needle on the temp gauge starts climbing. When the car is warm it seems to behave but stop at lights for a minute or two and the needle starts climbing towards the max. I?m pretty sure the engine isn?t really overheating. I let it idle for 10 min and it doesn?t smell hot, no coolant loss and the fan kicks in as usual. Besides even if it was overheating I can?t see how the gauge would climb the instant it started from cold?
I tried changing the temp sender but that didn?t help. Could the gauge itself be faulty? Or the connections on the back of the gauge? Anyone else has this problem?
Forgot to add, the oil temp seems normal. On a 100 mile run down the motorway it stayed at a constant 90 degC.
try overfilling for a short while and see if this solves it
Run car till warm and fan kicks in and add water to radiator till it bubbles over. Repeat till no more bubbles..
cheers mat
I would love to get my hands on a Haynes manual for this car - but cant seem to find one on the net anywhere
J
My cabrio recently started doing the same thing. Temp gauge rises from the moment i turn the key and eventually sits around 7/8th of the way up.
If i leave it to idle, the gauge goes all the way to the top and the fan cuts in.
Its definately not overheating as ive measured the temperature of the block and rad with an infra red thermometer, but i'm lending the car to a friend for a few weeks and would like to get it sorted…
if temp gauge still rises the red/yel wire is shorted somewhere, if not then its the sensor at fault or an airlock as above.
bleed coolant system as follows, this method has never failed me:
If you have an issue with the coolant system, the 1st thing to change is the header tank cap (MK1/2/3 Golf/Polo/Passat etc). The older black caps have a problem with the pressure valve in the cap which can vent to late/early, so its always a good idea to upgrade to a new blue one.
The system takes just over 5 litrs when empty, there will always be some coolant left in the block unless you remove the thermostat though
Use G12+ coolant from VW, or G12 from AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
Use at least 40% coolant, I normally use a 50:50 mix in my GTI 8v and it runs nice & cool
Bleeding the system after refilling:
Run the engine from cold with the cap off and rev it to 2k now and again. While you are doing this squeeze all the pipes you can get your hands on, and keep the coolant level topped up. It will eventually start to boil over, at this point turn the engine off. Once its settled down top it up to the max mark and you should be good to go!
Checking the operation of the system:
Check the lower rad pipe is stone cold until the temp gauge reaches the half way point, if it gets lukewarm straight away then the thermostat is stuck open or missing, if it stays cold then it is stuck shut.
Check the fan kicks in when the gauge gets near 3/4, if not disconnect the plug from the radiator sender in the bottom, passenger side of the rad & bridge the pins. If the fan spins then the temp sender is broken, if not jump the fan direct from the battery, if it still dont spin then the fan is knackered
