Engine Swap...
(In Topic #72359)
Engine Swap...
_____________________________________
83 Golf GTi Campaign - Diamond Silver - Light mods
83 Golf GLi Cabbie - Mars Red - Heavy mods
If you had one of these 'bubble block' engines, you'd need a collar for the dizzy and a blanking plate for the front of the engine - both sold by TSR
Cheers,
Mark
Cheers,
Mark
I have an Audi 80 block like this (from a '93 car, 2.0E with AAD engine code), and because the block is a few mm taller than the DX block you'll also need a "sandwich" spacer plate to go between the exhaust manifold and the down-pipe, other wise you'll be straining the exhaust system and it will be knocking on the floorpan - TSR supply these, with the other parts mentioned above (that you'll also need for this block).
