engine swap mk1 to a DIGIfant
(In Topic #76650)
thanksss
Just picked up the lump with box and loom etc. Although the loom has been buthchered a bit…..
TT
good luck with urs matey hope it goes well
Engine is in mated to original gearbox, I had to drill ot the holes on the block and put two high tensile 8mm bolts through to attach the drivers side eng mount.
I used the original alternator as the multiplugs are different.
I have moved the coil but need to move it again as I need to cut a big hole in the bulkhead for the massive grommet for the wiring to the ecu.
As far as I can see at the moment the engine wiring loom is all you need wiring wise. The coil either needs wiring modifying from the engine loom or use a mk2 coil. Next problem is the airbox, using standard might mean re-locating the washer bottle but a cone filter will solve this.
As soon as my ignition is wired back in (car was stolen and only spade connectors remain no multiplug so am struggling with how to wire it!!!) I will see if it barks!
Will keep you posted on progress.
MK2 GTi 16v
