Engine randomly dies
(In Topic #80892)
Time to start reading the old posts on the fuel system to give you an idea where to start .
Start at the simple and work your way methodically through the system . How is your filler neck , when was the fuel filter changed ?
Chudd
ANymore comments will be good.
ignition switch?
Does the car have a sunroof? as they are prone to letting in water which usually trickles down on top of the fusebox and causes all sorts of hassle
So many dubs so little time, so much rust
Re: ignition switch?
vvallabh82 said
when you say ignition switch do you mean the relay?
Sort of! it is a relay in the bottom of the barrell NOT on the fuse box.
changed it and it cured my problem!
Carl
