Engine mount bush replacement
(In Topic #234393)
Says the new bush is 64.7mm but the internal distance in the gearbox mount is 63.5mm. Its not bent or warped.
I get that its an interference fit so its jammed in tight but how on earth is that supposed to press in?! I cant even get it started in the mount, even in a vice or a press.
Any help appreciated. I have the drivers side bush en route also
Get a board 2X10X 2foot. Drill a hole in it the same size as your mount center.
Fill a 5 gallon bucket with 3/4 water.
Take your mount bracket and heat it up Cherry Red.
Holding the mount with a vice grip place it on the board, quickly take the Dry ice and place it in the bucket. Take the mount out of the cooler and orient it, and place it in the mount bracket, and one smack or two with a hammer will move it in place, quickly quench it quick in the bucket of dry-ice water.
Been doing it that way for years.
Im tempted to just cut a slot in the mount where the bush fits, expand it a millimetre or two. Slide the bush in and then run a seam weld back along it whilst its clamped tight in a vice.
The drivers side bush comes tomorrow, will see how that compares in its mount!
The bushes arent expensive, might buy another and compare
As you say though, the bush shouldn't really measure more than the housing.
