engine knocking help !
(In Topic #77021)
it is only small nosie at the moment but i dont want it to get any worse.
am i right in using semi syemthetic oil
any ideas any one :dontknow:
1983 lhasa green mk1 1.8 gti
old skool baby
old skool baby
If its nocking then something aint right and the coice of oil is unlikly to have affected it.
Did you have good oil preasure from the word go?
TT
I told you it sounded mad but my daa uses it all the time to locate a problem.
As you've guess not an easy solution but you may have to drop the sump and check the crank bearings one may have been installed wrong/loose etc.
You should have a warrenty on the engine for that amount of miles?
Rob
Audi A4 1.9TDI - Gone
U going to the meet tommora chap?. Can you get Parole! time? Just use the get out of jail card m8. :mrgreen:
i would still like to know the corect oil for the car then i have got rid of knock.
this is a real low point for me as i have spent so much money, so much work,and a wife who thinks i am mad but i still love the car but i just what it to be as good as every one says that are.
is 500 miles ok for running in , since then i have gone to 6000- rpm twice once to beat my mates rs escy and the other to beat a bmw [no prob] i am not giving it to much stick am i , if my sprite can cope then so sould me golf
old skool baby
old skool baby
satelliteone said
Rob your good for ideas 8O , Im gona look mad with bits of wood hanging from the side my head. The neibours think im already insane. :roll:
I'have you know My dad ,(Fully trained Mechanic and walking Haynes manual!) uses it often for diagnosing faults.
Sorry can't make it this month promised my boy skating at Eden before it shuts next week (or is he the excuse for me wanting to go 8O )
Have a good un
Rob
Ross
old skool baby
old skool baby
is it a clicky tappy noise
Cheers,
Ross
Hopefully you've not done any damage and the above is only a guide for a fully rebuilt engine every one will tell you different things but that is how my impreza was run in and I was very strict with oil changes in between and started off with a mineral oil especialy for running then after 1000 miles I went semi synth and fully synth after 3000 miles.
I would say a good 10w/40 would be ideal for most Golf GTIs.
You need to take it back to the garage and get them to check - you must have some kind of warrenty for it???
Racing is life . Anything before or after is just waiting - Steve McQueen
As far as I can recall a small end or big end would knock under load, or all the time if it's bad, NOT under decelleration, or am I going off on a tangent ???
If it was a timing problem wouldent it be more likely to knock when accelerating rather than decelerating ?
Oh Yeah, I misread that! Wouldn't hurt to check it though!
defiantely coming from the engine? even in or out of gear?
berty said
it's a 1800 gti and i am gutted i thought u lot would say this was normal but it is not is it. i hate that sump with the two stupid two bolts that you can not get to .
I know how you feel my car before the golf, I replaced the engine then 400 miles later ended upside down in the middle of the road!!!!! aaaghh :cry:
the piece of wood trick will help you isolate the tappits easily :wink:
On running in, it's always recommended to use standard oil or running in oil to help the rings bed in..ie you want it to wear, synthetic oil can cause the bores to glaze and prevent the oil control rings from doing there job effectively. as Mr_GTI says you should not rev it hard until you've done between 500 and 1000 miles for the same reason.
Rob
as its only a second car i will still use it a bit , go easy on it for a bit and see if it gets any worse.
i know the 6000 rpm was silly but how hard is it to run a gti in when the voices in your head says more power a bit more power it wont hurt a little more power.
old skool baby
old skool baby
Rob
LOL its true I know, this is how come I had to replace the impreza's engine - damn TVRs :twisted:
