engine identification....
(In Topic #76396)
Hey.. just joined.. just bought me a tasty Mk1 Cab…
Can anybody tell me by these pics what engine is fitted to it though… there is a bit of confusion….
log book says 1.8, owner says different! can probably get the engine number off it by tomorrow.. which one is it?
Rich
Rich
Its an 1800 gti engine, i think the code for them is DX
Whys it got the WUR on the head instead of block? :dontknow:
Could it have a non standard bottom end?
Hi, thanks for the replys!!
I know the gearbox has been changed at some point… but as far as i kno to a standard one..
has a mild cam in it aswel, can just about figure it out by the blue on the cam pulley.
But the dumbass gal was tellin me it was a 2.0, and i was saying it was a 1.8!! so yea thanks anyways..
What kinda 'bolt on' mods can be done to the gti, apart from cams and cylinder head?!.. i am guessin it is the 8v right?!? soz but golfs are unchartered territory for me.. ask me anything about a A series mini engine and i would know tho!
Rich
Rich
It is an 8v, but the person you bought it from could be telling the truth, theres every chance that someone has fitted a 2ltr bottom end at some stage. Look on the block, at the top right hand side theres a small flat machined surface and the engine code is stamped on there. If its a standard 1800 gti engine im pretty sure Dx is the correct code.
hi.. didn't get chance to get engine numbers today.. will do tomorrow tho!
Any ideas on mods?!?
Rich
Rich
Rich
If it has a 2 litre bottom end already and an uprated cam then really you cant do much else without bigger bucks apart from k&n exhaust/manifold bigger throttle body/warm up reg, then its head work/bottom end balancing etc.
