Engine cutting out!! Help!!
(In Topic #77820)
Having a problem, any advice would be more than welcome…
Its gradually got worse through the day, started off cutting out at some traffice lights, then again…managed to get the car home and now it cannot keep ticking over unless applying some revs…
Gary
i had this and the missus had filled up and not put the cap on proprly
hope that helps
Stu
www.msportcam.co.uk
1272 driver with a magic tree!!
lowmk1 said
sorry to sound dumb here but mines got the same problem…wheres the dizzy?ops:
Dizzy is slang for 'distributer' and it's the part on the front or end of the engine (depending on what model engine you got) with the 5 ignition leads going to it, one from the coil, and one to each spark plug. You can get problems with cutting out if the cap and arm are very worn, or dirty or if there's dampness in it. Ocassionally they do go wrong as well, particulalry if the car is high milage and all the parts inside it are worn.
Mike.
1983 White cabriolet GTi
