Engine coolant flange condition
(In Topic #220770)
I have seen this though - but with a C at then end of the part number - same part?
https://www.autodoc.co.uk/car-parts/oem/026121133c
Last edit: by cdgthreesalmons
It will work fine, fit a new seal and your good to go.
when you refit be sure to tighten the 2 bolts gradually, else you can crack the end off the casting where the bolts go
rubjonny said
could smooth it out with some careful application of chemical metal. Mark Carter of classic-vw.co.uk has new ones I believe.
If I may add, apply never-seize to the bolts then tighten them down by hand equally until tight. Switch over to the 1/4 drive in/lbs torque wrench and set to 87 inch/lbs, you can find the Metric NM setting in the Bentley. It won't crack the ears, it will fully seat and function and you won't strip out the head…Don't ever trust your elbow torque wrench…
