electronic ignition question
(In Topic #78713)
The dizzy I bought looks as new, but it has a green rubber O-ring fitted just below the gasket that goes between the dizzy and engine block… :dontknow: Should I remove this O-ring before fitting it?
The number on the new dizzy is 026 905 205 AK and the old one is the same but ends in letter R
many thanks,
yal
Matthew
Does it make difference that my new dizzy has different letters behind the vw code?? Both are 026 905 205 but the old one says R and the new one AK. The both look identical, but I dont know if the advance mechanism advances more or less degrees.
I went to vw to order the paper gasket that goes between the dizzy and engine block but they dont sell it anymore!
About 10 years ago I changed my golf GLS to electronic ignition (I was fed up with contact breakers) and I then bought the paper gasket at vw which would prevent the dizzy to get stuck with the engine block.
Does nobody use these gaskets anymore??
greets yal
