DX Engine Rebuild
(In Topic #101591)
DX Engine Rebuild
i took a 125K lump apart and the bores were perfect!
Only way is to look!
at the top of the bore is there a ridge (approx 10mm down) if so how deep?
The other thing is to buy a set of rings and see what your clearance is
c&r enterprises and got a 2ltr crank so with a rebore and some clearance work its gonna be a 2ltr but still look stock
toast said
If the engine is supposed to be a 1.8 would it be 1.9 pistons i need? Anyone know of a suplier?
the next oversize will be about 0.5mm greater than your current bore.
although you could fit 83mm pistons to take it from 1781cc to 1870cc (1.9) which is what i'll be doing with my G60.
alternatively, there is the audi 3A 2l bottom end conversion, details can be found here: http://www.vwgolfmk1.o…ontent&pa=showpage&pid=39
which would work out cheaper than buying new pistons for your 1.8. but if you were to get the 3A block and then find that it needs new pistons, you're back to square one.
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
