Cylinder Head questions...
(In Topic #136260)
Having a go a sorting the head gasket myself, after a dye test pointed to a problem. I'm a novice, please bare that in mind !.
Got the head off today, just got a few questions if I may:
Took the cam off as I was gonna attempt to change the valve stem oil seals and lap in the valves. This revealed what I think is some fairly heavy scoring on one of the cams/bearing. All the others had some light pitting but not as bad. Can this be fixed or is it a new head/cam ?. (probs with photobucket at the mo, otherwise would put pics up).
Also, the engine is an EV engine code and has hydraulic tappets. When the hydraulics are squeezed using thumb and forefinger, should they be solid and not move, or be…err…squeezable ?. 7 out of 8 of them could not be depressed. (hope that makes sense ?) I'm assuming they need replacing, as the one that does move bled oil out of it.
Lastly, there is some very slight left right movement in the pistons. The bores seem ok, and it's very very slight, say 1mm if that. Is this normal or something that may need looking into ? (please say it's normal !!)
Apologies for the numpty questions, but could use a bit of advice.
Thanks in advance.
Paul
The guy I showed the head to said this "i've worked on hundreds of these VW heads, but never seen a cam that f****d before !". Backed up your thoughts and suggested I look for a replacement. Have tracked one down, just need to make sure it's ok.
Out of curiosity, anyone know which model the EV engine code comes from, and if it's similar in power to the original DX ?.
Paul
i need someone to take a look at mine and live in colchester
