cutting out randomly!!!
(In Topic #114865)
My car cuts out randomly and then five mins later it starts again then…..5 miles down the road it cuts out again. I have a hunch that it maybe the fuel pump or fuel pump relay as most other things have been done to my knowledge. Does anyone have any suggestions? Also are fuel pumps and relays easy to find and fit??
Dan
mk1 golf gti 1800 8v (k-jet) cabriolet 1990 (typ 155)
Look inside tank via inspection hatch under rear seat with a torch
As far as all the work ill try and remember:-
Module
ht leads and new sparks + d/cap
new ignition switch
coil
other stuff was done as well that was under the ?500 but doesnt effect the engine work.
Any ideas?
Also another bit of information for you guys….
When i fill the car up with a full tank of fuel the car runs fine and will maybe only stop once or twice if that..but once it goes below half a tank the car starts to play up by doing its usual cutting out thing.
if it does the same thing its not the switch, if that sorts it then its the switch or the wiring.
another test you can do is hook up a timing light to each ht lead, if you see tyhat its sperking while the engien is turning over then that shows that there is at least a spark, though it wont show you how strong it is.
Corder said
When i fill the car up with a full tank of fuel the car runs fine and will maybe only stop once or twice if that..but once it goes below half a tank the car starts to play up by doing its usual cutting out thing.![]()
On a Cabby…??? have you checked the fuel lift pump in the tank….my filter was disgusting ….see below..
http://www.vwgolfmk1.o…=2833&highlight=lift+pump
what seems the problem
christiaanzian said
hi there i got a mk1 1.4 carb when i pass 120kmp then its starting to cutting out
and then i put a ffz 5 gearbox then a chsnge the gear links to 5 spesd but still i dont get the 5 gear
.. desperate.
