cutting out problem...
(In Topic #78847)
I'm having problems with my gti cutting out. The symptoms are:
car runs fine too and from work every day 2-3 miles
take it out on a run & it cuts out (although not every time)
turns over fine. but will not fire
take lead off distributor cap and no spark
leave it for half an hour(ish) starts up no problem
I fitted a new coil at the weekend and took it out on a run no problems
Went for a spin tonight and it cut out again. Waited 30 mins. & started
Can anybody help ?. Any ideas would be much appreciated
Racing is life . Anything before or after is just waiting - Steve McQueen
You can hear the pump running when trying to restart
I'm borrowing an ignition module tonight to see if it helps.
please keep the suggestions coming in just in case this doesn't work!
Although the ignition switch does sound another potential option
Cheers guys
dizzy
Your other post asked if there would still be a spark. The hall sender sends a signal to the ignition module which controls the coil producing the spark at the right timings. No signal no spark. Broken or breaking down hall sender, no spark.
Heres my post
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=8891
Hope it is your module as new dizzy ?130.
Cussco
Seem to have sorted the problem. A friend of mine noticed the small three pinned connector going to the dizzy body was shall we say knackered. He replaced the connector & stuck on a dizzy he had got already for good luck and no problems. He suspects a combination of the two…anyway went to Harewood hill climb on Sunday & no problems what so ever.Even the oil warning buzzer didn't go off so it might have cured this too…!?
Thanks for feedback
