cutting off/revs dropped several times
(In Topic #122282)
Since then, its cut off three times while on a steady run (usually anything above 30mph) but i've noticed if I keep the accelerator floored the revs quickly jump back up and prevent the car from completely cutting out.
The last time it happened was today and just before I got to a petrol station. It cut off completely this time and it took ages to start (kept turning over but wouldnt get going) So as anyone else would do, I looked under the bonnet. The only thing I found was- the grub screw next to the throttle body missing- :eek: i've replaced the grub screw and now the car idles at 2000rpm- I believe this can be adjusted so the revs will be lower on idle?
Anyway, the main thing is the dastard cutting off. Can any bright spark shed anymore light on what the problem could be? :dontknow:
Many Thanks
could be of similar nature to whats happening to you
Member of the month GET YOUR SAY IN NOW
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=86608&highlight=
the revs dropped from about 3000 to 0
As you noticed the rev counter going from 3000 to 0 as soon as it cut out , it points to an electrical problem .
The rev counter is driven from the coil - loose power to it no rev counter [if it was fuel related and you were still getting a spark rev counter would read engine revs] .
Loose fuel pump relay / and or terminals to it / faulty hall sender / faulty wiring to them .
Good luck ……………
