Crank pulley removal, allen bolts worn, try center nut?
(In Topic #77603)
I am trying to remove the crank pulley so I can remove the lower timing belt cover and then the timing belt itself. A combination of rust and crud in the heads of the allen bolts means the allen socket has no purchase and the 4 allen bolts are not for shifting
Any help appreciated.
Dhillon
83' Gti
Yes the centre crank bolt is very FT
See this and try some of the techniques and tricks. If you still can't remove the 4 then try the centre;
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&p=53747#53747
When I had a Polo Diesel VW themselves made a mess of this when changing the timing belt. They ended uphaving to removed the crank pully and replacing all 4 bolts, pulley etc and charged me. This was on a car just a few years old. That chance have DIYers at home on one 20+…. :cry: not one of VWs best designs
As the engine is out of the car I have plenty of room to work on it. Just enough room to get a good swing at the bolts with a sledge hammer, the bolts may even decide to pop out themselves (looking all sheepish) when they see me returning with the sledge hammer.
The impact driver is a great tool to help free bolts and screws, not forgetting the WD40 of course.
Adios :wink:
