Core plugs
(In Topic #128321)
Core plugs
What should I expect to find on the other side of the core plugs. Coolant or oil ?
Just trying to work out if I need to drain the coolant first or not.
83 mk1 GTI
bought a house so need to start hiding what i buy from the wife
its not the best of jobs lol
83 mk1 GTI
freeze plugs?
anti-freeze does NOT taste good…let me tell you
stuporman
\"Why do I always have bolts left over?\"
If I had to do it again, I would probably remove the offside driveshaft too, there really isn't a lot of room to swing a hammer in there.
And I did still get a bit wet, even though I removed the water pump to drain the block, there was about another 100ml or so of coolant behind the plug. It would have made sense to flush the block out with water while I had the pump off, but you live and learn.
