Cold start splutter for about 20-30 seconds!
As you can see from the pics the state of the old coolant flange! cream crackered isn't strong enough what i want to say or how i'm feeling about this issue!!! Looking at the inlet of the flange you have the inner part, the rubber seal & then the outer part - all contact the Cylinder Head, the inner bit is corroded to hell, almost to the rubber bit!!! so i think this has leaked into the lower bolt fitting of the coolant flange (front of engine too) & rusted it badly!! Looking at the receipts from a certain AP Engineering in Essex they, as part of a job, said they had 'sealed' the coolant flange! YES WITH SOME KIND OF RUBBER SEALER LIKE ON A WINDOW!!!!! i kid you not! so at the moment i have got a 6mm TAP, helicoil set & new 10x1 mm pitch bolts. I need to drill & re-thread this. I am so peeved with what has happened you won't believe it. When i have actually done this i am hoping with the new parts, as mentioned, it will start & run fine - with no cold start issues!!!
take a look at the pics - & if anyone hasn't done water change for a while or got no record i highly recommend it!!
basically went to attack my car as per my previous 'update' above, Saturday morning, got my tools & stuff together & decided to go for it… got a mixture of liquid metal & hardener together & filled the damaged 'hole' from the shredded bolt head… thought it better to drill & fill to start from scratch if you like. Filled it & left it (recommended 5-10mins solidifying time in 20degree temperature - it was about 5 degrees Saturday morning!) So with this i tried to see if my drill & bit would fit - NO! Radiator cowling was in the way
So… cleaned the wifes car & my daily & felt good, sun was shining so onwards & upwards! disconnected the rad, took it off no probs - had the room. The liquid metal mixture had gone off
Put in a helicoil
pulling the relay would mean no fuel pump, and without fuel the engine wont fire.
his gauge displays water/coolant temperature. If a problem is sensed by the warning system, the red light will flash. The sender for this gauge is mounted in the upper radiator hose flange on the cylinder head. 1990+: The warning light is also tied into a level sensor mounted to the coolant reservoir. Normal Reading The needle should be around or on the light under normal operating conditions. In stop-and-go traffic, drive-thru lanes, etc., needle may climb higher (this is due to little air flow through the radiator). Usual gauge operation: needle climbs to the right edge of the light, fan turns on, needle drops to left edge of light, repeat. While cruising, the needle generally stays over/on the light. What temperature corresponds to the needle reading? Very good question! It all depends on what thermo switch is installed in your radiator and which thermostat is installed. The standard, OEM thermo switch is a 95-84° switch. This means, for single- and two- speed fans, the radiator cooling fan will turn on at 95°C (203°F) and run until the coolant temperature in the radiator is down to 84°C (183°C). So, if you have the standard thermo switch in the radiator, when the needle reaches its highest point on the gauge and the fan turns on, the needle is showing a coolant temperature of approximately 95°C (203°F); with the needle directly over the light, the coolant temperature is approximately 87°C (190°F ~ I say "approximate" because, as stated elsewhere, these gauges are not 100% accurate), which is the temperature when the standard-temp thermostat opens. Needle Pegs to the Right and the Light Flashes If the needle pegs to the right and the light flashes at start-up and remains this way, test the coolant temperature gauge sender as it may be faulty (disconnect the connector; if the light stops flashing and the needle drops, the sender is faulty). Gauge Reads Low (Needle Stays to the Left) If coolant gauge is reading low even after the engine is warmed up, it's indicating that the thermostat and/or the gauge sender is most likely faulty. Test the gauge sender (CIS -- disconnect the connector and ground it; Digifant --disonnect the electrical connector and jump the yellow/red wire and brown wire terminals); if the needle moves upward when you turn the ignition key to battery-on position, the sender is faulty. (Digifant: If needle doesn't move, jump the yellow/red wire terminal to ground; if needle moves upwards, your brown ground wire is no longer connected to its ground point and requires repairing).
There are Hansa ignition leads currently on the car??? I've changed most things on the car, renewed, not heard of Hansa.. so got Bosch arriving next week…
Took her for a spin last night… when i start & go to pull off straight from cold - it's flat, bur bur.. no acceleration, put my foot on the clutch, rev then it's ok… rev it again for a few seconds & away it goes… when cruising @ 60 now & again i would feel the smallest of judders, barely anything… uuurrrrgghhh!!!! so frustrating!!
no connection to the block itself, just those 2 fuel lines
When I removed mine one of the heads of the bolt sheared off as the bolt had rusted into the WUR, luckily I could undo the other one and turn the WUR around to screw it out of the engine but I had to remove the oil filter housing to do this.
I would give it a good soak with Plusgas or similar and go carefully.
I use this stuff but as with any rusty bolt it could still snap.
http://www.eurocarparts.com/ecp/p/car-accessories/car-maintenance-accessories/maintenance-fluids-and-greases/penetrating-fluids/?549774741&0&cc5_857
Limited to what i can do for a week or so.. going to order a WUR seal, take it off, clean & put back on.. think there is mesh/gauze on the block so i will clean this too - being careful. Had my CV's done - which were brand new last year (garage did them for nothing of course) Got an oil leak - believe it's from the rocker cover gasket, i will get a rubber gasket & get it fitted within 2 weeks… just wonder if the engine loses pressure through a leaking gasket??? nonetheless, get it done & hope this resolves the common oil leak known with a cork gasket… things are looking good..
