CO Adjustment Screw
(In Topic #72891)
CO Adjustment Screw
Do I turn clockwise or anti to adjust as there should be a bit more air getting through than the stock one.
Also do I need the special VW tool as suggested in haynes.
Clockwise for richer. Think it's a 3mm allen screw?
Use a gas analyser and also bring the revs up and down between adjustments to allow the mix to stabilise. Make sure you take the tool out each time you rev the engine!!!!
Doesn't clockwise lean it out? (less fuel)
My Build Thread
Domain parking page
Also, the plug in the metering head use to be a small plastic thingy which you just prised out with your fingers (yellow or red in colour), only time you should need to drill it out is if someone or something has pushed it down the tube
crazyquiff said
Mmmm - Al, I though that clockwise lifts the metering pistion compared with the air flap which should richen the mixture.
It is a 3mm allen key.
Yes - I think you're right.
I'm getting confused with my Nitro RC car. That is clockwise to lean the mixture!
My Build Thread
Could this be why when I pull away in first unless I use lots of revs it likes to kangeroo. 8O
Bit of a long shot, but… friends GTI was doing that recently - turned out one of the vacuum hoses had come off dizzy. Worth checking connections for air leaks.
1983 1100 C
1983 1100 C
I'm now off to bend me 3mm allen key and check me vacuum hoses.
Thanks again
I want one.
Peter.
1980 1600 GTI, daily driver.
I think it's supposed fit to into the hole so it also blocks the hole to stop more air getting in?
Mind you I have put my finger over the hole with engine running and theres no real difference.
Peter.
