CAR WONT START
(In Topic #144347)
CAR WONT START
THE CAR IT WAS NOT RIGHT NOW IVE TIMED IN UP RIGHT ITS NOT FIREING UP JUS TURNING OVER
IVE HAD IT RUNNING IN BETWEEN WORK THAT BIN DONE
I JUST CARNT GET IT TO FIRE UP NEVER HAD THIS PROBLEM WIVE ANY OTHER CAR IVE REPAIRED
ALL NEW PARTS
FUEL TANK
FUEL LINES
FUEL PUMP
FUEL FILTER
OIL
OIL FITER
PLUGS
HT LEADS
DIZZY CAP
ROCKER COVER GASKET
ANT 1 LOCAL WHO MAYBE ABLE TO LEND A HAND FIRST GOLF IVE OWND
the trouble with only using the intermediate shaft marks is they only work if the dizzy has not been messed with, if it has the int shaft mark could be ay out.
for this reason i always ignore the intermediate shaft marks when i time up an 8v, i just check the dizzy position and make sure the rotor arm is aligned properly with the mark in the edge of the dizzy housing
still not runing
