can anyone help please
(In Topic #119196)
WHITE MK1 GOLF CLIPPER 1980
running
should sort that out a treat.
here for a good time, not a long time
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
Check this, if your bung is missing start the engine then put your finger over the hole and this may sort the problem (permenantly when you put blank in). I would definatley check the idle adjustment screw; if these things don't cure your fault check the timing.
In my case, and probably yours, it'll be the Auxiliary Air Valve (AAV). It should bleed extra air to the engine when cold to raise the idle, but they go wrong and raise the idle when warm too, leading to the problem you mention.
It's located on the back of the inlet plenum chamber, facing the bulkhead. Quite hard to see or get to, but easy to check; There's a rubber air hose, about 20mm outside diameter, leading to it round the left (as you look at it) side of the engine (offside of the car). With the engine idling (high presumably), squeeze this pipe with your fingers to close it down - you'll probably see the revs drop as you constrict the hose, and rise again as you release your grip.
In my case, unwilling to pay quite a bit for a new one, I've just clamped a jubilee clip over the hose and effectively blocked the air passage. The idle is obviously now a bit low during the warm-up phase, but it doesn't stall, and of course it's fine when warm. Worked ok for a year so far…
