Blowing manifold due to snapped bolt
(In Topic #204538)
So from the front of the car it's the second tube from the left and it's the top bolt, it couldn't be in a worse position.
Any ideas on how to get at this? I've got zero visibility, huge hands and I'm rubbish at this stuff.
So gutted it couldn't be a more annoying issue.
I when back with SS bolts using never sieze, the bolts I used had a Driver head, they were off a Saturn SL1.
They never broke again…
I still used new copper nuts. and the external threads of the studs got never-seized as well.
I am a good guy with a Left-Handed drill, but on a head I took the "chicken" route….
You may also find it easier to work on/get to if you remove the inlet manifold as well.
Sorry to say it's not a 5 minute job….
If you do remove the manifold/down pipe and use the original studs make sure you replace all the nuts for copper ones.
GSF and Euro car parts did sell them or you can get them from ebay
http://www.ebay.co.uk/itm/VW-GOLF-MK1-MK2-MK3-T25-CAMPER-CORRADO-EXHAUST-MANIFOLD-STUDS-NUTS-x-8-A712-/221605260320?fits=Model%3AGolf&hash=item3398b3ec20:g:br0AAOSw2XFUZdO6
Or you can up grade as the post above.
Last edit: by mark1gls
Think this will have to be a garage job
If you do get it done at a garage and they remove the inlet manifold it may be worth getting them to check the bolts as looking at your picture the bolt head looks as if it's starting to round off?
My machinist said that on VW's Mk1's they used a 8m stud, and if they had gone to a 10 or 12 stud thes kinds of things wouldn't of happened.
I guess I was lucky that I got my g60 4-2 manifold at a breakers that was already off the car
