bloody k jet injection !!!!
(In Topic #114856)
car wont start !
not sure what the problem is can anyone help, am not sure if cold start/5th injector is working properly, if you turn ignition on and leave for a few seconds the engine tries to start but will not run, but if you turn key and crank engine straight away you get nothing ?
., if you lift the flap in the metering head and prop open slightly the engine will run and rev quite happily, if you replace vacumn pipe( big black plastic one), nothing happens
engine cranks over quite freely throughout but wont fire up other than the afore mentioned, its getting very frustrating, has anyone any fault finding tips or suggestions
any help will be gratefully received ? :? :?
whatalotafun said
i've heard that this and "cold start" is "addictive" to engines and after useing it regular cars are then reluctant to start without the stuff, is that true??
It can be. The engine burns more agressively on it and wears the piston rings and bores, lowering the compression and making starting harder etc. I'd suggest to use it for fault diagnosis only. Basically, if it starts with cold start fluid but not without, then its a fuelling issue of some kind.
but seriously folks ????
i only want to drive the bloody thing !
weedeater said
lmao thanks fellas !!!![]()
The 5th injector is easy to test. You remove it and see if it squirts a mist of fuel. Take precautions to prevent a fire/etc
If its not working, test the electric side of things.
If its an electrical fault, check the wiring and the thermo time switch, its not a complicated circuit (see manual for diagram).
Let us know how how you get on.
This "i've heard that this and "cold start" is "addictive" to engines and after useing it regular cars are then reluctant to start without the stuff, is that true??" EQUALS stay away from drugs and spirit for a while until your head clears. I mean, come on now, have who ever told you that explain just how it would happen
it lives !!!!
k jet
paul_c said
Try spraying "Start ya bastard" into the engine.
