big question
(In Topic #72720)
big question
1) just as a good bottom end rebuild and
2) a bottom end rebuild with nitrous in mind?
I'm a bit unsure on a few points of a bottom end rebuild. I'm an ok mechanic but have no major bottom end experience. If I replace the main bearing for the crank do I need to have the crank re ground or anything? I know that the shells have to be matched up correctly if you remove and then refit them, so what do you do when fitting new ones??
Lots of questions I know but I would be very grateful to anyone that can help.
Ben :?
Guest user
I removed my 1800 bottom end from my Mk1 after 124K last year and replaced with an 1900. I had a look at the engine once it was out and it had virtually no signs of wear.
As suggested above, if it does let go, which I very much doubt, you can get a replacement cheaply enough.
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
However, doing the sump gasket last weekend showed (apart from a brown 'tinge' to the engine) everything looked in very good order. The sump plug had no metal 'fur' on it which did surprise me.
So quesiton is, will it be false economy just to do the head?
Here are a couple of things to consider :wink:
I went to a track day at Mallory park last year and had a ride in Greame scotts (ex TSR)red Mk1 which was a standard 1800 but with 205K on the clock!. It also had a pack D head/ 4 branch/ jettex etc giving a good 160 bhp. It revved for england and was sweet as a nut. Colin Mc intyre ( slick 50 racer!) had a Mk2 1800 there then too, almost the same spec and never had a problem with his either.
Here is some proof of VW reliability, but it's up to you
MK1 Golf GTI 1900
MK2 Jetta GTI 16V
MK2 Jetta GTI 16V
