Best place to buy Coolant Hoses
(In Topic #154458)
It's an 83 Tintop GTi
smudge18 said
Can anyone recommend where to buy a set of rubber hoses for the coolant system? While I have the system drained dow, I am replacing water pump and thermostat and might as well replace all the hoses. How many are there?
Hi
You can buy a standard set from vw heritage, there not sold as a set though, I dont know of anywhere else that sells all the hoses. Think its seven. I am going back a couple of years though
baz
Do I need this one too? http://www.gsfcarparts.com/179VG0710
Last edit: by smudge18
Chairman
smudge18 said
Thanks for that. I take it you did that today? 8 in total? Great.
yip
you also need that pipe, not sure why thats not there, its my shopping cart from 2-3years ago. Ignore the silicon rubbish & buy standard lol
Chairman
Why rubbish??
Dano said
I thought the standard black silicone stuff was pretty good.
Why rubbish??
Maybe they are good, but under any bonnet of a mk1 gti the original look is best especially if its a daily. I removed my orignal 30 year old coolant pipes probably about 3 years ago not because they had failed so they do last. Personally i use my mk1 gti most days & due to the design of the air flow there would be no point in fitting fancy coolant pipes as the road grime just hits everything head on inside the bay.
baz
Chairman
bazmk1 said
I noticed 1 of the pipes we need 2? is that correct?
see the pipe at £19.17, dont think you need that, no idea why its that price. Also yes your right the you only need 1off the £1.83 pipe
http://www.merlinmotorsport.co.uk/SAMCO-HOSE-&-KITS/c16/index.html
I was only one hose as thats all I needed and it was here the next day! I would recommend the company.
And you can specify a matt finish !
Chairman
I wonder if they would do them at a more competitive rate than main stream suppliers???
