Audi ABK on DX Head?
(In Topic #123674)
"Never Knowingly Understood"
'84 Mk1 Golf GTi Campaign
I am probably gonna take the 2e off will87cab's hands as long there's no clearance issues that you know of?
I have an OMP strut brace, and a Magnex Stainless 4 Branch Manifold will this not cause issues?
I know a machine shop that can fabricate the block off plates, so will just need the dizzy adapter kit from TSR.
I will also be after a dx head to rebuild…
This will be my first engine build but dont mind getting my hands dirty, so any pointers greatly appreciated.
TSR dizzy ring
Blanking plate for block
Multi-layered steel head gasket
New head bolts
Suitable exhaust manifold
Rear diesel engine mount
Mk1 golf sump
Due to the increase in cc these engines require to breathe more, a ported & polished head would be nice, so would a better cam but in the 'real' world these cost a fortune for only a few more bhp (maybe 10-15) over standard 130. Any enlarging work on the head wouldn't go amiss though.
Use the 2.0 cambelt but change the audi tensioner for the standard Mk1 one, it's less than half the price and does the same job. You could also uprate the oil pump using the Mk3 16v and fit a Mk3 diesel windage tray but again this could be done at a later date.
Good luck
The nearest thing to the downpipe is 26mm away from the manifold with a dx in.
I am gonna just bite the bullet and go for it…If I can pick up another cylinder head off from a dx then I can build it up before hand, and make the swap a bit simpler.
Anyone know best technique for cleaning the block? Would blasting of any sort be ok?
Do you know of any pics of one mounted to the blanking plate? so I can get a rough idea.
thanks again
jonwilliams84 said
do you reckon it had something to do with blocking that secondary oil breather?
With hindsight thats what i wondered as it was low mileage fairly newish engine and shouldnt have suffered with excessive crankcase pressure.
When you say leave it as is with the outlet tucked into existing pipework, where would this need to be plumbed in? Could it go into a T-piece and then into the pipework for the existing oil breather?
Like this?
Courtesy of the author of http://www.bailey.org.uk/engine-conversion/ :wink:
Will I have any issues mounting to the gearbox? i.e. the fly wheel clutch arrangement?
I am pretty certain its a standard box, if not one from a scirocco with a taller 5th, cause it is only pulling 6000rpm @ about
135mph…
