Another Oil Pressure light/buzzer question ! Sorry!
(In Topic #89251)
I've done a search and cant seem to find any deffinate answers/solutions. Basically when driving at low RPM (2000'ish) after a while the oil pressure light/buzzer comes on and as soon as I blip the throttle over 2500rpm it goes away for a bit till I've been driving under 2500rpm for a while again.
I hear this is a common fault, but cant find the soloution!
Any help to a new proud (and clueless) MK1 owner would be cool chaps.
Neil
Ooops forgot to add my cars a 83 Campaign GTi
Neil
I have a similar (but opposite) problem. My oil light comes on when the engine is cold and if I go over 2000rpm. Once warm it goes away. Never found a definitive answer to this problem. I've heard that blocked breather pipe coming out of the rocker cover can sometimes cause this. And also the gauze within the rocker cover itself. Have you tried cleaning these out?
1983 Lhasa Green GTI
neil, chances are that it is a faulty sender. probably the one on top of the oil filter housing. a cheap solution, and if wrong, not a large expense.
it worked for me. :dontknow:
my car has been doin the same as this too! i cant believe ive found someone with the same problem - i try and describe it to people and we dont know whether its an electrical fault or the actual engine itself. it does it when the engine is cold to and i rev up a bit..then goes away around the same time every day but the light constantly flashes, we've tried new senders - hasnt worked, its sooo annoying.
Some help would be good!
however although this doesnt seem electrical my temp gauge has also stopped working. grr
Mine seems to do this but at random times. Is it a conspiracy :shhh:
1983 GTI-Black
MY very first one AND LOVING IT!!!!!
I used to have the same problem thing used to go off all the time and i replaced the sender as marsredgti said and havent had it come on in over 2 years and they only cost a few quid
GTI_Jack said
I used to have the same problem thing used to go off all the time and i replaced the sender as marsredgti said and havent had it come on in over 2 years and they only cost a few quid![]()
Where can you get the sender from?
1983 GTI-Black
Local spares shop, GSF, Euro car Parts or main dealer which is where i think i got mine from, but only ?5.90 from GSF
GSF?? I'm new
ops:
ops:
1983 GTI-Black
GWtaylor said
GSF?? I'm newops:
ops:
Car Parts & Spares -- Buy Online with Fast UK Delivery | GSF Car Parts
i got a new sender..but it didnt work! haha :dontknow:
I've got one too but not got round to fitting it yet as it's such a big job
Is'nt there two oil pressure switch's tho, one on top of the oil filter and one on the side of the head? for high and low pressure?
I'm sure I read that somewhere !
i had the same problem but as soon as i rev'd my car over 2000 the buzzer came on, it turned out to be the L shaped curcit board in the back of the clocks!! common problem aparently.
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
Life Member
Can I joint this buzzer club mines the type that goes off when cold and then stops after about 3mins i use it to tell me the engine is warm it only started when i swapped the engine for the TSR Donnington.
never found a cure for it yet. :dontknow:
Every great icon needs to have a nemesis. Nelson had Napoleon….. Sherlock Holmes had Moriarty…… Dangermouse had Baron Greenback. :starwars:
The mk1 golf has the oil buzzer.
Yeh i never had that problem either until i swapped the engine over to a different one the same as A50PY! still havnt solved the problem!
