Altenator advice please
(In Topic #195453)
Can someone please tell me what altenator I need for an 89 GTI cab (DX engine code) I'm having issues with mine not holding a charge as I can no only start the car with a set of jump leads. The battery looks good (approx 18 months old) I've check the wires, cables, earth straps etc cleaned up the bettery terminals, plus the starter motor is only about a year old so my next stop is the alernator ???
Any help / advice is welcome as I can't really use the car at all as I can't start it again once I've stopped and the local petrol station seems to take a dim view of me breaking down on their forecourt everytime I need to fill up, which is now as I ended up running on fumes last weekend !
Cheers.
Paul do you have an immobiliser of any sort?
They only cost £12.50.
http://www.ebay.co.uk/itm/VW-GOLF-MARK-MK-1-2-SCIROCCO-BOSCH-ALTERNATOR-VOLTAGE-REGULATOR-C694-NEW-/371049330563?pt=LH_DefaultDomain_3&hash=item5664437783
You can mine was a little worn out!
golfcabrio said
As above.
Hi Mike, I stripped the alarm system out ages ago as it was shot to pieces and kept going off on its own
mark1gls said
Check what voltage you are getting at the battery when the engine is running, if below 14v clean the alternator regulator connections and if the bushes are worn out replace it,
Cheers, I'll ty to have a look at the weekend (weather permitting)
Like you it's getting old, not totally shot but just can't handle it anymore!
Measure Voltage between battery terminals engine running and from the + ouput on the alternator connection. That way if there's a big difference between the 2 it could be down to duff connection or poor conductivity through the cable.
Have you tested the battery? Looks and age mean nothing. If it's been discharged and left that way for any period of time it'll have sulphated.
I take my battery out of the car during winter.
