Acceptable oil temperature 18.gti?
(In Topic #116701)
Got a 1983 1800 gti with the oil radiator coolnig arrangement
after a "vigorous" run temp is up at 124 deg on the mfa which seems pretty high, mk2 runs down at 98 or so using the water cooled arrangement. and im sure if see lower temps in the past before but If im honest I havent thought about it much
Searching around on the net suggest this temp on a mk1 may not be unusual/ unacceptable? what should I expect?
wondered if the rad want working properly but
Bottom hose to the oil rad is hottish to the touch, cool on the top (presumably return hose?), does that suggest all is working correctly on that front?
anything to worry about? :?
Chris
is it likely to be the sender or the MFA , latter seems to work ok although MPG is wildly out
If its too high presumably must be the oil cooler
bottom hose is hot top is not, so does that mean its working right?
pull the sender out, add an earth wire too it then put it in jar with boiling water from a kettle and a thermometer, this will give you an idea how accurate the maf is, (normaly within a couple of deg or so)
secondly is the oil cooler getting warm? i suspect now, it should open at just over 100deg, (110iirc) they are prone to sticking… easy fix is take the 3 bolts off the front carefully and take the stat out (watch the spring) and clean up the slider area, look for scoring, wipe all bits down and rebuild,
you shouldnt really be seeing above 120, 110is the highest I liked to see on track use, and 100 on road, also check what oil you are running and make sure the breathers clear etc to help with the oil control.
