Acceleration delay and judder
(In Topic #83279)
i'm getting a serious judder when pulling away in first then a then a delay when in acceleration in first and second, any ideas?
1982 1.8 gti
1982 1.8 gti
hows your fuel pump? is it sounding noisy? :dontknow:
rebuild in progress....
haven't checked the fuel pump, but i'm not getting any noise.
Have you got a lack of power when you put the car under load but will idle fine.
I did with mine and it turned out to be the small filter inside the fuel pump which was clogged up, just a thought.
www.vwcaddy.com
OK i had this problem the whole of last week, and it turned out it was that my mixture was wrong (fuel/air). once adjusted it worked fine.
However my car now will not start at all, so i'm thinking either ignition leads or fuel filter.. : /
See here for a similar thread, you may recognise the symptoms.
