5th injector?
5th injector?
I have been to look at a MK1 gti to possibly purchase, but it has a 5th injector, what and why are these installed??
Are they for performance only, or smooth running??
All advice is grately appreciated thank you in advance
The 5th injector is the Cold Start Injector.  It is used for 8 seconds when starting the engine when cold to richen the mixture.  It is controlled by the Thermo Time Switch.
It is located on the cam belt end of the inlet manifold.
Rich
Crazyquiff's Mk1 Golf Parts Emporium
www.golfmk1.co.uk - you know you want to….
Are the 5th injectors standard, or have modifications been carried out Possibly due to cold start problems?
Completely standard
_________________
'82 Black 1600 GTI - Getting Better
The 5th injector is a standard feature of most earlier fuel injection systems. (Later ones have the electronic capability to increase fuel delivery at startup through the regular injectors). It provides extra fuel, to overcome the cold temperature of the piston/cylinder at startup. I guess less vapourises and neat fuel exits from the exhaust.
Other cars (I don't think K-jetronic, though) also use the 5th injector to provide enrichment in situations such as acceleration demand. So, it could be used to enhance performance, but not in the Golf GTI. The Golf varies the stoichiometric ratio by the shaping of its air mass meter (which is a mechanical device, not electronic) and the 4 regular injectors have enough capability to provide the extra fuel.
Exactly what I was gonna say.
1980 1600 GTI, daily driver.
If my 5th injector were blocked/knackered would that explain why I have to keep the revs up to about 1800 when I start my engine for the first time of the day? If I don't it dies. After about 10-15 seconds of revs it's fine.
probably not.
The manual says you should slightly depress the accelarator when starting a GTI.
I have my 5th injector unplugged (another story) and Mine starts up fine.
Your problem could be so many things. Would need to do some simple tests and identify other symptoms to diagnose. E.g. could be ignition.
Peter.
Far too long a word for a monday morning.  :roll:
1983 White cabriolet GTi
tallpete said
probably not.
Peter.
On my car it should say 'fully depress the accelerator' and maybe 'pray'
Shonky
'82 Mk1 GTI 1870 160bhp
'83 Mk1 GTI 1800 (Now deceased)
'80 Mk1 GTI 1600 (Now deceased)
'81 Mk1 Golf 'C' 1093 (Long-Awaiting racecar transformation)
Audi A8 Sport (Gone but not forgotten)
Toyota MR2 MK1
Turbo Technics MK1 Golf GTI's - where are you ?
http://www.VWTurbo.co.uk
I can always sort that problem out for you Turbthenicsmk1 by taking it off your hands I`ll look after her…..
 :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :lol:  :wink:  :wink:  :wink:
If everything in life was as good as the MK1
There goes the deposit on the house Kev  :)
Infact, the last time I drove my Mk1 was when I saw Alec open his garage door to show me his rather nice Mk1  :D
MK1 Golf   GTI 1900
MK2 Jetta  GTI 16V
