2H to GTI
(In Topic #222923)
What's the difference?
From what I understand, the later versions were restricted for the cat required overseas. My cat has mysteriously disappeared, so what else would I have to change? I have heard mention of a different cam and different ECU, but nothing definitive.
Any thoughts?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I never had issues with it being restricted….
All OEM save for the down pipe/manifold.
I have had it over 95 on occasion .
Wouldn't there have been a mapping change with the cat?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I haven't seen there being an issue with a CAT delete, and I have had cats Puke out the internals and Plug the Silencer a wee bit…after getting that sorted, I didn't see a need to re-map for a cat delete.the_whip said
What I'm trying to figure out is the difference between my 97BHP and the GTI 112BHP.
Here is the Math
112
- 97
_____
15
So how much are you willing to spend for 15HP?
Is re-mapping a ECU and there are some suspect chips out there that are not cheap, but the good ones are…..
You have to get it to breath easier also if you are running a small throttlebody, then getting a larger one will help.
You will get more SOTPs(Seat of the pants) HP out of opening the intake to your airbox for a larger diameter, a K&N Filter along with a 4-2 Manifold and Dual Down pipe…. than the ECU remapping….. Just saying 15 HP?
Little more cost but well worth the effort than justy an ECU re-map, and after getting the intake and exhaust to flow easier, you can then re-map to increase it even more….
I agree that 15HP is not huge, but 15% is still a bit on what (let's face it) is not the most powerful car.
A new throttle body sounds interesting. I'll have to check what I have now, but I imagine it's stock. What do you suggest? Most of the info out there is never for the Digifant (or doesn't it matter?). 4-2 manifold and dual down pipe seem a bit more involved.
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Golf GTi 1.8 litre 8 Valve (PB)
90 on
Bosch Digifant II
0 261 200 298
0 261 200 299
037 906 022 N
XEVD22N
90 on
Bosch Digifant II
0 261 200 298
037 906 022 DB
XEVD22DB
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Think I should try it?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
I was looking at these:
https://www.ebay.co.uk/itm/VW-GOLF-MK2-GTI-8V-PB-INLET-MANIFOLD-DIGIFANT-2/193059872440?fits=Car+Make%3AVW&hash=item2cf343deb8:g:Rn0AAOSwRq9dXVsY
https://www.ebay.co.uk/itm/MK2-Golf-Jetta-GTi-8v-Digifant-Inlet-Manifold-037-199-223A-PB-engine-code/283502595904?hash=item4202124f40:g:pDYAAOSw0dZc8Zbr
https://www.ebay.co.uk/itm/VW-MK2-Golf-Jetta-GTi-1-8-8-valve-PB-intake-inlet-manifold-037133223A/283515172258?fits=Car+Make%3AVW&hash=item4202d235a2:g:6toAAOSwWxBdAhIl
*Edit* Inlet the wrong way round?
Last edit: by the_whip
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Whip
/wip/
Noun - Car
/wip/
Noun - Car
if you were converting from a kjet to digifant you would have to change the inlet so all the digi bits can be bolted on, mk2 inlet faces the wrong way though so that would mean moving the airbox over to the driver side and all that jazz
Not at all. More like…rubjonny said
sorry if that sounded a little short,
Whip
/wip/
Noun - Car
/wip/
Noun - Car
Apparently they are okay.
Any thoughts?
Whip
/wip/
Noun - Car
/wip/
Noun - Car
