•.Hunting Idle.••.Problem.••.Solved.•
(In Topic #127029)
I'd checked everything:
Distributor
Aux Air Valve
Cold Start Valve
Pressure (Warm up) Regulator
Fuel Pump Relay (this shares 12V with pressure regulator)
…the list goes on, but finally solved the issue and it was the simplest of all. The o ring on the idle screw was not keeping the vacuum presssure.
Hope this helps others
'worn out gasket on your idle air adjustment screw which is on the back of the throttle body. If you thread the screw out and it looks flat like the nearest one in the image then you have a vacuum leak and it needs to be replaced'
Distributor
Aux Air Valve
Cold Start Valve
2005 Porsche 911
2012 VW Polo
1983 VW Golf Campaign (sold)
1990 VW Golf Sportline (sold)
2012 VW Polo
what wad the idle sitting at before solved problem?
Jay
1990 - MK1 GOLF CADDY PICKUP | 1980 - MINI GT 1275 | 2005 - RENAULT TRAFIC CAMPER
kinda sits near all way in, bar a few turns, but best way to set this is alongside timing and c/o- if you can turn it by hand...seals way gone.
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'93 GTI Sportline
Mk1'82 2.0L 8v
where did you get the replacement seals from? VW?
Matt
Matt
just std lil o ring bud - any motors spares gaf will have em
Mk1'83 G60
Mk1'82 2.0L 8v
Mk1'82 2.0L 8v
dont suppose anyone has a spare screw valve do they as mine isnt even there ?
. i have plenty of o'rings, just need the screw..
Thanks u mad mk1 monkeys
