Which Weber?
(In Topic #212496)
1985 1.6l Mk1 Cabriolet
Im looking to do a Weber conversion on my 1985 1.6L Cabriolet currently containing a Pierburg 2E. As you probably know the carbs are renowned for playing up and I've had constant problems since buying the car. I was looking for advice on which Weber carburettor its best I change too?
We use weber dcd7 36 carb(in South Africa at altitude),you will just need to put an adaptor between carb and manifold. For economy you can use the following:We use weber 38 for racing
weber 36 dcd7 settings
stage 1(primary) stage 2(secondary) |
choke 25 26 |
mains 120 145 |
airs 205 160 e/tube F23 F30 |
idle 50 |
pump 50 Timing 28 deg @ 4500 rpm (using 95/98 gas) |
