What radiator do you have in your 16v?
(In Topic #201921)
My car has always run quite hot, I've never had any real problems but the needle on the gauge tends to sit over the half way mark and if it's a hot day and I'm driving in town it gets even hotter. I does kind of worry me at the time to see the needle get so high.
I believe the 16v engine in the mk2 Golf had a slightly larger radiator which was double cored to obviously cool the engine down much better. I also read that anything other than a genuine item isn't as efficient, is that right?
I'm in the process of overhauling my cooling system and thought I may aswell look into other radiator options so I'm interested to know what other people are running and how good or bad they find them at cooling the engine.
http://www.clubgti.com/showthread.php?145091
If you do need a new rad get yourself a new 1.8 GTI 8v double core rad and all will be well. I've got one in my mk2 and its been fine with the 1.8 8v, 2.0 8v, 1.8 16v and 2.0 16v engines I've fitted
I used your cooling guide a couple of years ago on my mk2, very helpful.
I've just noticed I posted this in the wrong section
addign random additives wont really help, you may see a slight difference but if its runnign as hot as you say it probably wont be enough.
I've never had to mess about with any aditives on the 1.8 8v GTI rads, just use the std 50/50 mix of water and VW/Febi g11/12/13/13+/++/+++ etc
Where is the best place to get the dual core 1.8 one from?
Do GSF do it?
Or am i better to go somewhere else like VW heritage etc?
hella brand is pretty cheap on ebay, or nissens is good stuff. should be able to pick one up around £50 or less
only issue I had with hella rad on my mk2 is the mounting slot i needed was blanked so had to cut the slot open if that makes sense? may not be an issue in a mk1
The Caveat is that it had bosses for screws on the front side that I had to trim off so I would have no rubbing between my Radiator and my A/C condenser.
old one vs new.
I do know they used to make a solid aluminum one with the bolt mounts…
Since the Core was wider I had to remake my upper radiator card.
