Weber Woes
(In Topic #127184)
Weber Woes
Ok, splashed out on a brand new Weber for the cabby the other day but still having some issues.
It starts and idles quite nicely but when I give it the full beans it coughs splutters and stalls. Restarts fine and drives nicely and low/normal cruising speeds. Now I don't know a lot about webers or carbs in general but after doing a bit of research think my problem is to do with the secondary jet/circuit.
Looking into the carb with the air filter removed, I can see a squirt of fuel in the front barrel/venturi when i pull on the throttle but there is no fuel seen in the rear barrel, even at full throttle.
Is this a sign of a blockage?
Any help much appreciated, thanks.
Jason
Jason
'82 G40 conversion & '87 Cab
