webber carb for 1600 auto? series 1 manifold trouble?
(In Topic #90836)
i wasnt sure if the gearbox makes any difference, or the fact thats its from a later 1600.
any help apreciated.
thanks, Oli
Answers to both questions, NO
You'll be fine fella
Pete :wink:
i have just been told by solmone else that the carbs are diferent from manual to automatic gearboxes, with a different throttle linkage etc?
can anyone confirm?
thanks, Oli
gangstay said
thanks for the reply Peddersgolf.
can anyone confirm?
thanks, Oli
I have a 1600 auto with a Weber carb on it. I think the throttle linkage is slightly different, but its not too hard to adapt it. Basically, the original throttle cable is too short (it runs from pedal to gearbox, then gearbox to carburettor) so you simply use a clamp and another piece of inner cable, to extend it. Probably around ?1 from a cycle shop?
My mistake fella, it will have to have a mod somewhere.
It will bolt straight on, but will not connect to the accelerator cable without a mod. It won't have the gearbox kickdown on it, so unsure how to go about this, as i dont know fella, sure someone more clued up will help.
Pete
cheers paul,
any chance you could get a couple of pictures of the carb/ linkage etc?
ive found a webber second hand thats in good working order, but its for a manual car. would save me a nice bit of cash if i can use this instead of buying new.
has anyone on here done this?
thanks, Oli
a quick call to the local vw breakers and they have one on the shelf!
hopfully this will sort the mk1 out!
cheers, Oli
well , i got my carb today, the correct one for a auto.
but the base to attach to the manifold is completly different!
the carb is from a mk2, and the plate that sits between the carb and the manifold is about twice the size of my manifold, like a double opening instead of a single (if that makes sense?!)
i guess i need to order this part new?
any help apreciated, i want to get this golf sorted!
thanks again, Oli
sounds like i have the wrong adapter plate, as i made sure i got one with the kit, but didnt know what it was meant to look like.
current solex and inlet.
webber
the adapter plate that came with the carb
thanks, Oli
my inlet manifold is very different to yours paul, i guess i could fit the mk2 inlet manifold if its compatible with my head?
the webber carb has two butterflys at the base, but the existing carb only has one.
my inlet looks to be suited to one butterfly, where yours looks to be suited to two.
thanks, Oli
will a mk2 inlet mate to my mk1 head?
there is a mk2 in the local scrap yard, its either a 1.6 or a 1.8 driver
if the inlet is suitable, does it mak a difference what size engine the mk2 is?
thanks again, Oli
Oli,gangstay said
i guess the series 1 cars have different inlets then.
thanks again, Oli
the base plate you have their that come with the carb is the same for all 1.6 & 1.8 on both mk1 & mk2 bud.
Get an inlet from either 1.6 or 1.8 from a mk2 golf both same fitment to block,and sit your carb on bud
Pete :wink:
off to the scrappy tomorow morning then!
hopefully get it all bolted on tomorow afternoon.
any advce or pointers on fitting/ setting the carb up?
the mixture is pre set on webbers i think? so all i have to set up is the idle which i do when the car is warm and off choke?
the only real problem is where to mount the choke knob inside the car.
ive got the rear wash wipe on a button in the dash,(about 6 inches to the left of the sterring column) and it looks like this is where the choke would have been had it been a manual choke car originally?
thanks for the help guys
Oli
gangstay said
cheers pete.
Oli
To the left of steering column in pic below this is where the choke cable goes, if it has not had one fitted previously their will be a blanking plate covering the area, remove underneath panel, and on back of blanking plate is a philips screw, remove this and plate will come out bud
Set idle and co's once engine is at full operating temp, do best as you can with co's but i would advise taking to your local garage, and ask if they could do it on their emissions system, so you know you've got it bang on
Pete :wink:
that looks to me like where the choke should be, not sure if the rear wash wipe swith is original or not?
Oli
Not sure fella, have you undone the 4 screws to see if anything is behind it?
Pete
