URGENT help needed car wont start or run
(In Topic #85469)
The AA man thought it was a problem with my Carb and turned the idle speed right up and I managed to make it the rest of the way to leeds.
Husband has had a play with today completly cleaned Carb out as far as we can tell these no crap in it. put it back together again and the car was ildling fine so we took it for test drive but broke down and the about half mile up the road after car going juddery again.
The car now wont start and its as if theres no fuel getting through?
AS per my other posts Ive been having problems with the car juddering for about a week we changed the HT leads, Dizzy and rota arm last weekend but car has still been rough all week and we decided it must be the petrol Id got from tesco? but Ive filled up at the BP twice since.
Do you think I need a new Carb??
Any Ideas? :dontknow:
Car is a 1.5 with pieburg 1B3 carb on it.
Yorkshire Region Host
Mk1 Cabriolet 1500 (under resto)
Mk1 GTI
Mk1 GTI
am stumped! :dontknow:
Mk1 GTI
Mk1 GTI
Is the pump pumping fuel - you'll need to take the pipe off the carb, disconnect the HT lead at the coil, and then tun the engine over on the starter. Hold the pipe into a rag and you should get strong spurts of petrol - Please take care, No Sparks & No Smoking
Just a thought!
MKone your post is winging its way too you, sorry for the delay chap!..
We are going to do the measurement tests this week to see if too much or too little fuel is coming out of carb.
When I tried to adjust the idle whilst it was running the idle screw did very little to the idle. does this mean the carb is worn??
Off road now so no longer a daily drive so I have some time to look at it and tweak.
Thanks for your help I will continue to update if I find the cure.
Mk1 GTI
Mk1 GTI
mpg & Response is a lot beter with the weber carb.
The warm air nad vacuum feed probably gets ignored ui ost servuicing and the hoses etc break up over time. You can get vacuum hose by the metre very cheaply from a parts factor, worth replacing all of it if you are trying to diagnose a problem.
1983 1100 C
1983 1100 C
will keep you updated on any progress! none so far
Mk1 GTI
Mk1 GTI
He is running again
running like a bag of nails but running none the less.
Changed the coil, cleaned up points, tested condensors swore a little got shocked by the coil plugged it back on and away he went. (Roughly)
Played with carb a little but it sounds like a high pitched sucking noise.
checked all of the vacuum hoses, good suction there. Going to replace manifold gasket and carb flange this weekend and service the carb with a kit. so hopefully he may be back on the road.
Last weekend the weather was great and I was being reminded that it would be great to be driving with roof down. I did offer to chop the roof off the mk3 but she said no.
I will keep updating. Thanks for all your help.
Chris
Mk1 GTI
Mk1 GTI
