Two awkward sump allen bolts.
(In Topic #211676)
I got them off with a allen socket drive but it was a horrible angle and messed up the bolts somewhat.
long reach ball end socket 5mm socket bit? (or was it 4?)
http://www.ebay.co.uk/itm/Draper-Expert-5mm-T-Handle-Hexagon-and-Ball-End-Key-Hex-Allan-Allen-Alan-Keys/361394027807?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D2220072%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44293%26meid%3D08e8939b5ff1450686886a40ca0412ab%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D380979311079
Last edit: by Keith Usher
But I'm tight, yes a proper ball ended tool is the one.
Those are buggers on a good day, and I never thought about using a "Allen" bolt…(this is what is great on the forums….
I do use a 1/4 drive socket(shorty 6pt). and 2 Wobble extensions to get to them…. I also start tightening them by hand till snug, and used only a 1/4 drive Torque wrench to put them at 87in/lbs.
One day when I have to drop the tranny, I may replace the rear crank seal and carrier to totally fix,,,,,
Almost makes a case for Grinding the bell housing so you can get a Straight shot worth while.
I would think that the Ball-ended "Allen" drivers would be good in that situation as you can drive them at an angle.
