Tools for Cam belt change ?
(In Topic #117312)
I'm about to change my cam belt on the MK1
Can you recommend any special tools to aid this job?
I'm thinking of ordering a cambelt kit from euro car spares.
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.6_1980/p/Car-Parts/Engine-Parts/Belts-Chains-and-Tensioners/Timing-Belt-Kits/?348770285&1&7dc71877f790b512411cb1fe49e845cd7bfc59ab
Many thanks ('
Drysponge
Bert
a hammer for when bert trys to paint it blue
and if you cant get a bert an impact wrench will do. and if you round the allen bolts you'll need a welder to weld on new tops so you can remove them. simples.
This works really well, so much so that this is the way my mate deals with the problem - he's a technician at VW.
If you do suffer the problem with the rounded bolts you'll need 4 x M8 16mm replacement bolts. Even if your bolts come out ok it would be a good idea to put new ones in. Mine were less than ?1 and they are also stainless steel.
Hope it goes ok.
Projekt Frustration :
White 1991 Clipper. Lowered over polished zender rims, Single 40 dellorto on lynx manifold, kent cam, full stainless 'zorst / manifold, powerflex bushed and braced. Not the fastest car, but sounds super nice!
Still going after 12 years… never said it was a quick fix! Time is not my friend.
Also thanks, chris-h for the tip on new bolts etc! Some good advice there! ('
Drysponge
