Ticking engine noise
(In Topic #144040)
Have a look see if you can see any signs of black carbon anywhere…
85 Karmann GTI Cabby Black Edition
81 GTI Tin Top (1.8t "The Tarmac Muncher" )
10/15w40 spec oil is what vw recommend, I use quantum synta or fuchs titan always does the trick in mine.
but 50 is a bit thicker so in theory oil pressure should be higher in the head than with a 40 weight rather than lower? im no oil expert mind
as i say, im not so sure it is the tappets reading the symptoms again, if you listen to the engien at a cold start after its been sat for a week or so you'll hear the sound dry tappets make shortly before they pump up fully, compare that to how it sounds now see what you think
If any one else have any other ideas what it might be, please share it with me as i am keen to explore all possibilities.
for what its worth my 8v always sounded quite rattly around the manifold and downpipe area, no matter what i did. i think thats just what they sound like! i also notice now with my mk2 abf it sounds slightly blowy from the driver seat with the windows down, yet when someone else is driving it past me i cant hear any trace of it. very odd
my symptoms are:
tapping noise at idle, then increasing tapping speed when accelerating, and then goes quiet, and then the noise comes back again when sat at idle again, the noise will also disappear if i rev the engine sharp and quickly.
any help on the symptoms origin would be great!!
hi!
what was tha problem?! im having the same issue here
noise from my golf mk1 1.6 carb engine - YouTube
