Thermostat not opening
(In Topic #92229)
The fan is working if a cross the wires. Coolant looks ok.
After going for a run I found the top radiator hose roasting but the bottom one is cold. [No circulation]
Does this mean thermostat is not opening and needs replaced?
How easy is this?
thanks
cc
Here's a diagram of the complete system. It is a closed loop.
Refill with 50/50 G12 mixture (pink stuff from VAG) but don't mix with other glycol apparently or so another post advised on this topic.
MP
Looks a bit scary but I've got a manual somewhere.
cold bottom hose
is this the water pump gone ? surely if the fan belt is turning the pulley then it should rotate the pump inside, as it is a fixed shaft :dontknow:
anyone any ideas
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
When cold, remove the expansion bottle cap, start engine and rev it up, you should see water being squirted out of the long thin hose 14 on the diagram into the bottle. If so the pump is working OK.
Its not unknown for the water light to lie and flash at random. Does it ever do it when you know the water is cold? It also goes off if water level is low. The switch in the expansion bottle or its connector might be U/S.
expansion tank
Does the car actually over heat, ie boil up and loose water???
overheat
there is water still in the redundent water tank, so have no light flashing and yes it overheats if run for a while, with steam coming out of the rad filler
I can't remove water pump to see what's going on though according to the manual I've removed all 4 bolts. Any clues what's happening. I've tried gentle persuasion.
water pump
the expansion tank is not used as such, as it contains the windscreen wash
dont understand it as the connectors at the rear of tank are connected correct for the screen wash, but it has a hose that looks like it should connect to the rad, but the rad fitted is a top fill :dontknow:
its been flushed til water runs clear, everything has been correctly fitted, so whats going on :dontknow:
anyone :cry:
