The Mystery of the Intermittent Startup
(In Topic #201630)
Hope you're well this holiday season.
I really hope you can help me out. As you'll possibly recall, I own a 1.8 carb non injection Clipper Cabriolet, 89 reg.
Since purchasing it a few month back, I've encountered intermittent issues with it starting.
This was initially fixed by means of a new fuel pump, but now the problem has returned and although it attempts to turn over, the car doesn't start.
So far, I've had new
Distributor cap
Spark plugs
Battery
Fuel pump
Fuel filter
It's been suggested I check the spark plugs to ensure one hasn't suffered an untimely end, and that I check the distributor cap to ensure the leads are in the right firing order.
I'd be grateful for advice on whether this is the right approach, if I'm missing an obvious issue, and as to what the correct firing order would be.
Thank you!
Start with basics. Pull off a lead and put an old spark plug in place near the engine see if you have a spark.
Next check you have fuel either remove plug and see if they are wet or fuel line.
Does the car have an alarm or immobiliser?
