Strong exhaust gas smell
(In Topic #217200)
Does anyone know why my car would have such a strong exhaust gas smell. The smell is really strong if your outside the car when it is ticking over or if you pull up somewhere and put the window down you can smell it straight away, I don't remember it been like this before. Hope this is in the correct section.
Lemon Yellow Tin Top Restoration
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=your-mk1-golfs_2%2Flemon-yellow-tin-top&kfs79=30
Exhaust sytem leaking.
Check the colour of your spark plugs.
Roach said
Out of its tailpipe or in the cabin/front end?
Out of the tailpipe
mark1gls said
Fuel mixture out, running to rich, air filter old or dirty.
Fuel mixture / running rich might be worth looking into. Air filter is fine and the exhaust system isn't leaking. Will also check the spark plug colour
Cars rear Hatch seal not tightly sealing.
Along with the short tail pipe extension causes fumes to enter cabin.
Holed Exhaust.
Now running rich is another issue.
Most of mine are white with NGK lettering
However this post is about a strong exhaust gas smell outside the car if that make sense
