Smoking in engine bay and exhaust when starting then goes???
(In Topic #128059)
My clipper had an idle problem so I replaced the old carb with a manual webber and it now runs and idles great. Problem is it smokes for about five minutes from the engine bay on start up - its very light grey and looks to be coming from under the carb or near the manifolds somewhere.
Over the past few days it has started to grey smoke from the exhaust within a minute of starting. This smoke is quite heavy but after a mile or two it disappears completely. Other than this the engine seems to be very smooth and runs great.
Is this piston rings or somethign else sinister? Or could it be something to do with the carb? I really hope i haven't got to replace or overhaul the engine because if I spend much more money i'm heading for divorce. Also wondering if anyone knows roughly how much this might cost me?
www.salientphotography.co.uk
hi
im favouring breather issue but you just never no till you start taking bits off
im sure some one else will offer some more help at some point good luck
On Friday I drove to work no problem but then it started to rain. On the 40 miles journey back I broke down on the Coldra roundabout near Newport (basically right on the M4). The car was juddering under acceleration and when I stopped at lights at the roundabout it cut out and despite a grumble refused to start. Had the police out and after an hour of waiting and diverting traffic in the rain the pick-up truck finally arrived. They towed me to their depot but when we got there the car start first time and seemed to be running great. But, as I rejoined the motorway it cut out again and this time the truck had to tow me all the way home after recalling them.
I had a look at it yesterday and the car started after a bit of effort. I couldn't see any damp on the plugs, in the dizzy cap or rotor arm. When it did finally start it kept dying but after ten minutes and plumes of condensation out of the engine bay and exhaust I could at least drive it into my garage. There was still loads of steam coming out everywhere and I've not wanted to take it out for any length of run in case it cies again.
So the question is where do I go from here? My garage who I trust say it is just condensation but could it be something else? The problem is its really unreliable now and despite spending about 2k since I bought it in July my Mrs is starting to get more than a little annoyed and wants to get rid for something reliable.
If anyone can help i'd be grateful or if there are any MK1 experts in the Caerphilly area i'd be happy to chuck you a few bucks for a quick look.
im sure some one down your neck of the woods will hav a look if u struggel pm me and i will send u my number and hav a chat to u if it helps vic
i had the very same problem as you!
the grey smoke is the clue, this is coolant dripping onto the zaust manifold and boiling off. mine had exactly the same
Thanks for the offer vic, its kind of you. If you could PM me your email address and how much you want for them i'll paypal the money asap.
have a read of the 2e2 faq guide, near the bottom of the 1st post is a short guide on it. hardest part is undoing the 6 bolts that hold it on, id advise you make sure you can get to them all before you start. if you do a hg it makes it easier, split the exhaust manifold from the downpipe then lift the head off with both manifolds still attached!
a mirror and thin socket extensions and allen bits are essential if doing the job in situ.
