Similar effects of carb icing but it's not!?
(In Topic #202950)
Thank for any help
Otherwise I would thing that if your tank had the internal anti-slosh baffle that it may have broken loose and is now possibly interfering with the fuel tank outlet.
The there is the Sheared Crank Gear syndrome which when I had that I could idle and any additional gas would cause it to stumble….
I suppose it could also be a bad fuel pump…..
Just a few things I have had happen to me over the decades……
May be worth having a look in the fuel tank and checking the filler neck.
Thanks again for your replies
87cab_bb said
What is 'sheared crank gear syndrome'? Sounds drastic lol!
It is when the Front Crank gear (pin) shears itself, and the timing gear can move at a different time than the crank.
Hard to diagnose, but lets just say, remove your belts and covers, if there is any lateral play in the lower Crank timing gear, something isn't right.
My issue was that the PO (previous owner) let a "Certified VW mech work on the car." When I purchased the car drove it 400miles home, no issues.
3 weeks later the car started to act the posterior.
1 month later, I found that the PO mech had used 110 ft/lbs on the main crank 12pt bolt. The bolt bottomed out in the crank, and bent. It eventually backed out just enough to allow the crank gear to slip.
This slip would allow the car to idle, but giving it gas would sputter lunk, act like kids that are bratty…. The timing was spot on about the first 7 times I checked….
Farging won't start.
fargin won't start. | VW Vortex - Volkswagen Forum
Spun gear repair.
Here is my complete Crank Fix.. | VW Vortex - Volkswagen Forum
My Crank bolt (only had a 1mp camera then) what you can't see in the pic is the bend at the very end.
Crank that was destroyed.
