running hot
(In Topic #91753)
running hot
Also is the fan cutting in? Lastly has the coolant been changed recently and are you sure it's full? I flushed mine the other week and had real issues making sure the system was full and devoid of air air pockets. Check the bottom hose on the radiator is getting hot too as if it's not the fan may not come in.
Tian
hose ??
what is the likely problem if the bottom hose is not getting hot ?
i just flushed the system and the bottem hose still isnt getting hot
any ideas :dontknow:
83 1.5 gl all black sold
86 1.8 gti cab all black light mods. restoring
87 1.8gti cab standard helios blue. daily driver
91 1.8 auto cab gold clipper. breaking
Basically if the thermostat was working before it should be working now. Let it warm up until the fan kicks in at around half way. If it doesn't kick in and it simply gets hotter. turn it off, you have an air pocket in the system.
Tian
air lock
im gonna try again in a min with the manual in front of me this time
Re: air lock
opentopvw said
nice one tian, didnt think it would be much wrong, whats the best way to get rid of the air lock ?
Take the bottom hose off and start again.
I took the bottom hose off and blew all the coolant out (don't suck)!. Once this was done and I was sure there was nothing left in it I replaced the bottom hose and added a premix of coolant and water to the top of the radiator making sure it was as full as possible. Then re-attach the top hose and fill from the expansion tank also.
Basically, fill it from as many angles as you can, run with the expansion cap off and top up or allow to flow over.
as for the manual, I used a VW Bentley's manual and it wasn't much help so good luck.
Tian
tried again
any ideas :dontknow: :dontknow:
Tian
fan
Re: fan
opentopvw said
nope
The thermostat is probably fine but wont work until it has a reason and that's got to be because it's not getting hot due to a blockage/air lock.
It took me a while and I did get very angry with it but you will get there in the end.
To make sure there isn't a bubble of air in the lower reaches check the amount of coolant the system should take and check to see if you're actually getting this much in there, if not the answer is simple.
One final thing, I'm assuming all was well before you started the job and this was simply part of your winter service, is this correct?
Tian
the day ends
im presuming that if it is at fault the water will not circulate :dontknow:
no the car is my latest project and i dont know the history to it, but it was overheating before i started it, the head gasket is fine , the rad seems fine, engine runs sweet but one thing i noticed was a redundent water reseivour, as it has a top fill radiator, but dont think that will cause the prob :dontknow:
im presuming that if it is at fault the water will not circulate No idea!
True enough.
Tian
water pump next
got a mk1 pump in the garage , just hope they are the same across the models as i cant remember which one it came off :dontknow:
so will try that and let you know
I know on some cars (not sure about golf) it is possible to fit it both ways and if you get it the wrong way it will not open properly.
Paul
'89 Clipper
'83 Audi quattro
'89 Clipper
'83 Audi quattro
Tian :wink:
fan
I've been having similar problems and just want to know who you got on in the end.
I know my fan works. I've flushed the coolant and replaced the thermostat but fan doesn't come on. Temp needle goes up to 3/4 mark but still no fan. Bottom hose cool top hose roasting.
By the way there's no expansion tank on mine (GL auto). Is that the norm? Last owner a bit DIY.
CC
I ran the engine hot till temp light on, then took the rad cap off. The coolant began flowing after a slight delay and after a few seconds the fan came on itself!
Air pocket must have escaped. All OK now.
for the tips
