removing carb
(In Topic #141743)
removing carb
hi how do i remove my carb , took airbox off but couldnt see the bolts that hold it to the manifold , is there something else i need to remove first
cheers j
cheers j
1991 1.8 clipper
There 3 screws mate, or bolts in a triangular pattern. Remove them and pull off
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
so are they easy to see
j
j
1991 1.8 clipper
Take airbox off, undo everything associated with the carb like wires etc, label em, then it's just the 3 screw bolts you'll see which ones the are mate. May need to tug it a bit if it's stuck to rubber gasket but easy to take off mate.
MK1 Cabby '90 R.I.P
'83 tin top gti
'83 tin top gti
Hi there, did u manage to remove the carb if so can you inform me of how u did it?
